Ford 1700 VERY VERY hard to start
   / Ford 1700 VERY VERY hard to start #11
Justin84 I don't think the cracked fuel filter housing is totally sealed if it's hard starting once hot but runs OK once started.
   / Ford 1700 VERY VERY hard to start #12
Are the alternator and battery doing their job? How fast does it turn over when you try to start it? Can you try a battery you know is good to see if that helps?
   / Ford 1700 VERY VERY hard to start #13
Do you get any smoke at all when the engine is cranking? Have you tried jockeying the throttle while cranking?
I put the throttle at wot to start then idle down once it does fire with fluid of course. I have a old battery on charger as we speak due to being out of town, i may buy a new battery tomorrow and then check with meter to make sure the alt is charging. Now as far as the cracked filter housing it doesnt leak at all.
to be honest i love the tractor but wish it had a loader, im almost at the point of selling it to get something else being im getting fed up with it
   / Ford 1700 VERY VERY hard to start #16
Have you tried to start the tractor at idle or just above idle rather than WOT position.
How long do you keep the glow plugs engaged before trying to start.
Have you tested the glow plugs as mentioned yet.
Also not advised to use ether.
Have you tried to start the tractor at idle rather than WOT position.
yessir ive tried all positions, i did run a jumper to the plugs today but battery was weak. I normally keep the key turned unit the wire is glowing red
i do get some blueish smoke while trying to start it
   / Ford 1700 VERY VERY hard to start #19
I had a 1700 and I had to use the glow plugs to start it even when it was warm out. My guess is you have s glow plug issue. I now have a 1920 and at 40f no glow plugs are needed to start. My 01 power stroke also below 60 degrees needs glow plugs to start. Good luck.
   / Ford 1700 VERY VERY hard to start #20
Running a jumper to the glow plugs won't help if the problem is with the glow plugs themselves. Have you tested the plugs as Tx Jim described in post #2?
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
CAT Skid Steer (A50322)
CAT Skid Steer...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
