Ford 1710, Shibaura H843 Engine parts?
   / Ford 1710, Shibaura H843 Engine parts? #1
ggtechman7
Estacada, Oregon
Rhino 202
I have the 1710, with the 3 cylinder, 1.4L Shibaura H843 engine, with a spun rod bearing, and a cracked cylinder head. Engine has new injector pump and timing gears. I am not finding parts to repair it, (gasket set, rings, bearings, cylined head). Does anyone know of a source? Are the engines available in Japan? Can they be imported? or is there another engine that could be retrofitted in place of the Shibaura? I have a Kubota 3 cylinder that I may try to fit in it (my winter project) Any insight is appreciated.
   / Ford 1710, Shibaura H843 Engine parts? #3
The New Holland TC35 uses the Shibaura N843L engine that is a longer stroke version of the N843. How similar the engine block might be to your H843 engine is anyone's guess, but I would think it would be closer than any Kubota engine.
   / Ford 1710, Shibaura H843 Engine parts? #4
Did you damage the crankshaft Journal any? Scott1700 has done same type of repair on 2 cyl 1700. He sent me a few emails during his work and shared some repair pics. I know he complained the parts were a bit pricey but was able to find them. You may want to send him a note and ask where he bought parts. I don't know if he regularly visits TBN. link below is his post after he finished his repair work. Scott1700 is his handle I believe.
JC,
http://www.tractorbynet.com/forums/nh-owning-operating/116843-non-smoking-section.html
   / Ford 1710, Shibaura H843 Engine parts? #5
Good luck on the parts search. I know of a 1400 that has a broken crankshaft and I have been looking for parts for months. These tractors are low priced but if repairs are needed they are not such a bargain. About a year ago everything was available but the new stock is no longer available. With the four wheel drive incorporated into the frame ( front axle ) a retofit may be difficult.
   / Ford 1710, Shibaura H843 Engine parts? #6
Parts for the 1710 are readily available for that engine Go to partspring. com and look at the parts book they have online and you can find all the parts you need and the prices. You can make up your list get total price, payfor it ander all right on that site. Their prices almost always lower than anyone else.
   / Ford 1710, Shibaura H843 Engine parts? #7
Your safest bet and best-bang-for-the-dollar, with such extensive damage is to replace the long-block. Shibaura and Perkins have merged and have a new plant in Georgia, but no one that I can find has knowledge of retrofits...
When I asked why not, the common response was that the demand for retrofits hasn't been large enough to make the effort cost effective. Since time is also money, most folks just cave-in, fork out the big bucks, and replace the block / long block / or engine with an OEM replacement.
   / Ford 1710, Shibaura H843 Engine parts? #8
I have a Ford 1000 with the Shibaura LE892 engine.
The pistons are siezed. I have soaked it in Mystery oil for several days now. Tried a couple of pops with a dowel and mallet. Dont get to move but a fraction.
Going to start the tear down soon. Any parts supplier here in the Central Valley of California that anyone knows about?
   / Ford 1710, Shibaura H843 Engine parts? #10
Garton Tractor, Kuckenbecker Tractor and Berchtold Equipment, depending on what part of the valley you're talking about.
2024 Kubota BX23S (Dothan, AL) (A50123)
2024 Kubota BX23S...
(2) 60" BELT DRIVE ELECTRIC SHOP FANS (A51248)
(2) 60" BELT DRIVE...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
Used 20' Container Box (A52384)
Used 20' Container...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
