Ford 1900 blowby
   / Ford 1900 blowby #1
Cretienlt
Newtown, CT
Ford 1900
Howdy,
I have a ford 1900 that I loaned to a buddy, I use the term loosely, In short it over heated and now has substantial blow by coming out of the valve cover breather /forums/images/graemlins/mad.gif.
Any suggestions as to where to start looking for the cause???
Cracked / warped head? Cracked block?? Blown head gasket??
Any help would be appreciated
Ray
   / Ford 1900 blowby #2
Blowby usually is created by the compression gasses that leak past the cylinder rings from the combustion side to the crankcase side as the engine is running. I'm afraid that the overheating may have weakened your rings and possibly scored the cylinders. Unfortunately the consequences of overheating an engine can be pretty destructive.
   / Ford 1900 blowby
K, I guess I need to bite the bullet and pop the head off and take a look see. /forums/images/graemlins/frown.gif
   / Ford 1900 blowby #4
Severe overheating causes the rings to lose their temper. They are no longer stiff and springy. They turn into "mush".
This could be the cause of your blowby. Find someone with a compression gauge for a diesel and check the compression.
Rich
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2015 FONTAINE TRAILER CO. 53 STEP DECK SPREAD AXLE (A50854)
2015 FONTAINE...
Sullair 185 DPO JD 100psi Towable Air Compressor (A49461)
Sullair 185 DPO JD...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
Set of Ag R4 Wheels and Tires (A52128)
Set of Ag R4...
