drakefamily2
- Joined
- Jul 23, 2011
- Messages
- 32
- Tractor
- ford 1700
Check this out Ford Clutch S.70911 Clutch Alignment Tool
\Thanks for the information. I am ready to put the tractor back together. How do I get the splines to line up so I can slide the tractor together? I have tried to eyeball it but I'm have trouble get it together. It is a double clutch. I don't have an alignment tool. I can get the front and back of the tractor within about 2 inches but it won't slide together.
Thanks.
only reason I mention it is i always repalce input shaft seal when doing a clutch.. so.. you got to work on it anyway..![]()
Good point. Do you normally change the seal even if you don't have any seepage. I look at the inside of my tranny and it is bone dry, nothing coming out from crankshaft or transmission input shaft seal. I still got 90% of oem clutch disk thickness left after 30 years... fancy that !!
JC,
