Ford 1910 4wd not working
   / Ford 1910 4wd not working #11
With the tractor in 4wd, that will hold the pinion from spinning. That is only if the 4wd is engaging the transmission properly.
If you are not hearing any grinding noise while rotating the tires, I would suspect the 4wd is not engaging at the transmission.
You can remove the 4wd drop box from the transmission and inspect the driveshaft, couplers and gears. If you remove the two bolts and remove the two studs (not just the nuts) you can lower the gear box. If your loader bracket is close to the driveshaft tube, this will not work. You will then have to drop the front axle.
   / Ford 1910 4wd not working #12
The first thing you need to do is check that the front driveshaft from transmission to front axle is intact. Pull the driveshaft cover back - most driveshaft covers telescope or have some way to check the shaft inside. So look inside the cover and see if you've busted either the front or rear U joints or splined couplings. The driveshaft is the most common place to break.
The second most common place for 4wd to go wroing is back at the gearbox with whatever kind of mechanism you have on or in the gearbox that engages the 4wd gear. For that you will need an exploded view of the gear box. I don't know what a "dropbox" is.
The front axle itself is less likely to break. They'll leak, and anything will break if it loses its oil.... but if the front axle had oil in it I'd look at the driveshaft or 4wd shifter for the problem.
Almost all these compact tractors are built with similar 4wds.
   / Ford 1910 4wd not working #13
Unfortunately on the 10 series tractors the front driveshaft cover is a solid tube. The only way to inspect that driveshaft is to remove the gearbox or front axle.
The term I am using "dropbox" is the gearbox that powers the 4wd driveshaft. On these tractors this gearbox hangs under the main transmission.
Ok, I will let everyone know what I find when I get back after the issue. I may not get back to it for a couple weeks but I will post what I find in hopes it helps someone else who runs into the same troubles. I really appreciate everyone who gave advice:)
Ok, I have an update. Today I drilled an inspection window in the driveshaft cover (about 1/2 inch diameter) with all 4 wheels off ground and tractor running in 4wd driveshaft turns well and has power from transmission. Right front wheel kinda turns but you can stop the rotation easily. I'm thinking it must be the splined coupler at driveshaft to front axle? To cover the small hole I drilled into driveshaft cover I used a piece of rubber and a hose clamp. Not sure why the factory didn't do that so anyone servicing could view the driveshaft????
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55301)
PENDING SELLER...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
