Ford 1910 no charging
   / Ford 1910 no charging #11
Thanks JC, You have everything on microfilm via the PC. Rabduck03 is having trouble getting his 1910 charging after rewiring it. I am sure these 4 pages will help him. Thanks
I hope Rabduck will find it useful. I have a 32 gigs of database that includes everything I worked on in the last 15-20 years (pictures and all), all catalogs, shop manuals for all my stuff (including 6 cars, Ford tractor and my newly acquired Kubota tractor as well). I just carry a duplicate of the data base on a $15 flash drive.
JC,
   / Ford 1910 no charging #12
I just love those flash drives and cards. 32 gigs is a lot of portable memory. The first computer I bought was a Commadore with a cassette for programing and saving info. The second computer was a giant step forward. A friend told me it would do everything I would ever need. It was an IBM and the complete Memory was 129 K (yes K) I now have 3 computers and an extra drive with 2 Trigibytes. There is never "enough memory". I take a lot of pictures. Ray
   / Ford 1910 no charging #13
I don't want of get off a tangent here but I still have my commodore 64 and it's huge suitcase size floppy drive (I was a little bit more advanced than you with floppy drive). When I was in engineering college we used bunch of C-64s to build Robotics and controls for industrial and manufacturing automation, very cool for that period. My wife did all her papers for graduate school on C-64. Prior to that. I even had a Sinclair with my B/W TV and a tape recorder for digital storage. lol.
JC,
My boys look at me with astonishment when I given the specs on what I have in the basement. Wondered if I can sell my C-64 on Fleabay.
I went and got the service manual today and I think I got it figured out. The previous owner must have wired alternator plug backwards. When I switched the wires around (N&F) the alt immediately loaded the motor down and the light turned off. Meter read 13.5 and held there for a while with head lights on.
It concerned me a bit when I saw a bit of smoke from the new reg but after a second or two it stopped so I assumed it was just burning a bit of dust/oil off of it. None of the wires were hot so I'm going to watch it.
Thanks for the help.
   / Ford 1910 no charging #15
Good to know you got it fixed. Let us know how it goes after a few days of starting and stopping and working the tractor.
   / Ford 1910 no charging #16
My 1910 was working fine until our 2 year old left the key on. I recharged and tested the battery, it shows OK, but I can't get any voltage to the field terminal. I had the alternator checked and got a new voltage regulator, which when connected, doesn't light the idiot light. I have done all the tests in the manual and am coming up frazzled!
   / Ford 1910 no charging #17
I'm having a similar issue. Replaced battery and alternator. The charging light on the dash keeps flashing, especially at low RPM's. Seems to get better (light out) with higher RPM's. Any thoughts?
Tractor is also a FORD 1910.
   / Ford 1910 no charging #18
Start with pulling the fuse panel cover and wiggling the terminals on the sides to see if any are loose. This was where my problem was. The wiring is pretty straight forward. Check to see if anything is loose and that the alternator is charging.
   / Ford 1910 no charging #19
checked all the wires, everything checks out. No loose wires. Could it be a voltage regulator issue or anything under the dash? Just strikes me as odd that it flashes, but only at lower RPM's.
   / Ford 1910 no charging #20
I have a Ford 1700 that stopped charging about a month ago as per the red charging light. Brand new battery that reads 12.5V and doesn't change with the engine running. I take it the wiring is the same on the 1700 vs. the 1910?
I have attached a pic of my alternator, which has 4 wires going to it as follows:
F, N, E and BAT.
Wires are nice and tight, even that broken plug on the F/N connector. Does anyone know the part number for that guy, btw?
Also, the 3 fuses are all good and the connectors there are tight as well.
I'll follow the troubleshooting guide posted on page 1 of this thread. Hopefully that will allow me to get to the bottom of it.
2014 GENIE Z-60/34 BOOM LIFT (A52709)
2014 GENIE Z-60/34...
1999 CPS TRAILER COMPANY BELLY DUMP TRAILER (A58214)
1999 CPS TRAILER...
500BBL WHEELED FRAC TANK (A58216)
500BBL WHEELED...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED WILD BOAR AR500 3/8" STEEL SHOOTING TARGET (A58376)
UNUSED WILD BOAR...
2009 MACK PINNACLE(INOPERABLE) (A58214)
2009 MACK...
