jinman
Rest in Peace
- Joined
- Feb 23, 2001
- Messages
- 21,059
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
Bob, I don't think I'd go that high. If it were 8 amps, I might go to 10, but a 5 amp jump is a lot. Blowing a 10 amp fuse is a significant short, indicating something definitely wrong instead of a slightly increased current draw.
Were these readings with the fuse blown? If so, your alternator had no voltage reference to the regulator and that's why you were not getting 14 volts. Since the fuse stops blowing when you disconnect the inst pnl, I would spend most of the time troubleshooting that.
DieselMonk, with the tractor running I was getting 12.2v at the battery and at the alternator. With all lights on it dropped to 11.95 at both. That's what made me think the alternator might be bad. If the alternator was bad, wouldn't that only be evident with the tractor running?
Bob
