Ford 2110 glow plugs
   / Ford 2110 glow plugs #1
bmartin172
Flintstone, MD
2019 Mahindra 4540 and 1986 Ford 2110
The glow plug indicator has burnt in two allowing power to flow to only one side of the indicator which does not charge the actual glow plugs. What's an easy fix? Can I just splice the wires together, doing away with the indicator? It will only be powered when the key is turned to the left right?
   / Ford 2110 glow plugs #2
The indicator is a nichrome wire which, in addition to acting as an indicator, drops the twelve volts to about 10.5 - the actual glow plug voltage. If you jump or bypass the indicator you will then be putting full voltage to the glow plugs. Other than the increased voltage the system will continue to work normally, though the life of the glow plugs will be shortened. You can find replacement indicators on eBay if you choose.
   / Ford 2110 glow plugs #3
I am going to give you a bit of a generic answer believing your Ford is a Japanese tractor in disguise.
If the glow indicator is a glowing piece of coiled wire, its real purpose is to lower the voltage applied to the glow plugs to around 10.5 from the battery's 12 volts.
The key switch plays an important role in glow plug operation. Never use an off the shelf switch.
When the key is turned to the pre heat or heat GP position power flows through the key switch, through the glow indicator to the actual glow plugs.
When the key is turned to START, the key switch bypasses the glow indicator and sends power directly to the GP's. The GP's are powered while the engine is cranking.
The glow indicator is bypassed during cranking because the current draw of the starter is already lowering the voltage the GP's see.
Replace the burned out indicator. Work around tricks risk over heating glow plugs which will explode inside the cylinder leaving hard shards of ceramic which can cut into any metal destroying your engine.
If you cannot find a Ford glow indicator, likely a Kubota B7100 will do. Measure the resistance of each glow plug to ground with the wiring removed. You should see around 1.0 ohms and if you do this is further proof the Kubota indicator will work.
glow indicator
complete indicator
Dave M7040
2024 New Holland Skid Steer (A52377)
2024 New Holland...
Power Horse 7000 Generator (A54865)
Power Horse 7000...
2017 Ford F-550 Enclosed Service Truck (A53422)
2017 Ford F-550...
2014 Nissan NV200 Cargo Van (A53422)
2014 Nissan NV200...
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
378721 (A54865)
378721 (A54865)
