Ford 3000 clutch pedal repair
   / Ford 3000 clutch pedal repair #1
ranyate3
Ford 3000
The clutch pedal on my 1965 Ford 3000 wobbles from side to side. I tried to remove it to see if the bushing is worn or if the entire brake/clutch shaft is worm. I could not get the clutch pedal off to see. There is a smooth headed bolt on the end of the shaft but I could not turn it. Does the entire shaft have to be removed? Anyone have an idea about how to easily remove the clutch pedal?
Thanks,
ranyate3
   / Ford 3000 clutch pedal repair #2
is there not a spring clip on the far end?
soundguy
Yes, the far end that the brake pedals are attached to, has a spring clip. So are you are saying that the entire shaft must be removed out from the left (clutch pedal) side? This would involve removing the left wheel. If this is done, does the transmission fluid require draining first?
Thank you very much for the information.
ranyate3
   / Ford 3000 clutch pedal repair #4
hit the nh website.. find the parts search.. from there you can pull up your model and then see exploded diagrams of the brakes, clutch, trans.. etc.. whole shebang.
might also check yer service manual...lotsa good info there. Mine's at home, so can't flip thru it for ya
soundguy
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
Unused 2025 CFG MH12RX Mini Excavator (A49461)
Unused 2025 CFG...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
2008 MAGNUM PRODUCTS LIGHT TOWER (A50854)
2008 MAGNUM...
CUSTOM TRAILER (A51242)
CUSTOM TRAILER...
2014 Kia Sedona Van (A50324)
2014 Kia Sedona...
