Ford 3000 New Carb, seems Governor isn't kicking in
   / Ford 3000 New Carb, seems Governor isn't kicking in #1
banc123
Bronze Member
Florida
I just put a new zenith carb (was the original holly) on my ford 3000. Fired up and runs fine other than when I was discing last weekend when it was put under load, the governor didn't kick it and add more power like it used to. It just sort of bogs down.
I had to lengthen the throttle to govern rod like 1/4 inch because it wouldn't reach the linkage. It had a threaded adjustment that just unscrewed to give it the little bit it needed.
I did also notice that at full throttle on the lever under steering wheel, it doesn't give as much fuel as it used to.
I was hoping to not have to mess with any screws on the carb.
Does this sound like a carb screw adjustment needed or some kind of adjustment on the throttle/governor ?
Whats interesting is when I connected the linkage, it was fairly tight and was wide open on the carb stop. But once cranked, it pulls back from against the stop.
I can move the governor rod with my hand once cranked to add fuel RPMs fine, but the throttle won't add any more fuel and the governor doesn't kick in under a load.
Thoughts ? Thanks..
   / Ford 3000 New Carb, seems Governor isn't kicking in #2
i've rarely bought a carb and installed it right out of the box and NOT had to adjust it at least a little.
Yours could be lean.
soundguy
I'm still stuck :confused:
The idle needed a little adjustment so it didn't conk out with the throttle all the way on low. When I moved it to full throttle, it was pretty smooth, but didn't produce as much RPMs as it used to at full. I added about 1/2 inch to the linkage between the governor and the carb, but had no effect.
If I watch the linkage and move the throttle fast from low to full, it revs pretty high then the governor kicks in and adjusts it back.
I gave the main jet screw two turns tighter and I couldn't tell a difference. I reversed that and then gave it two turns loser and the spring started moving so I didn't go any further and put it back where I started.
When discing under a load it slows way down and feels like its straining a lot. If I step on the clutch it revs back up. Before it was much stronger discing at the same depth speed and if it hit a big load, the governor would kick in and add more RPMs.
I went ahead and replaced the fuel tank shut off valve put on a new inline filter and fuel line just to make sure it was all clean.
Does it still sound like a carb adjustment ? I ordered the Ford manual late last week, but it hasn't gotten here yet.
With the throttle wide open, is there a way to adjust it so it opens the float more ? There is still plenty of room if I manually move the governor with my finger to make the float open more.
   / Ford 3000 New Carb, seems Governor isn't kicking in #4
float settings aren't soemthing you need to adjust for rpm.. the float merely operates a valve letting fuel into the carb bowl.
normally a zenith is a decent 'power' carb.. though fuel ineficient compaired to the holley carb.
are you sure you got the correct carb for your model?
it almost sounds lean.
does a lil choke help it any when it is low on power?
soundguy
I haven't tried the choke when its bogging with a load.
This is the Carb I bought, hopefully I didn't screw up. The holly carb that was on it had clearly stamped on top of the bowl C9NN9510A and R4119-1A
Its a 65-74 3 cyl , the original tractor was Ford 3000 , I had it rebuilt 2 years ago by a Massy Dealer who said the engine had already been rebuilt once and the replacement was a Ford 4000 engine ; which is what he rebuilt. But I'm sure the carb had C9NN9510A and R4119-1A stamped on it, so I went with the existing part # as the guide.
PARTS FORD Carburetor, New - With reversible linkage. This Zenith carburetor outperforms the original carbs used on- 2000, 2100. For 3 cylinder 158 CID engines. Replaces OEM# C9NN9510A, C7NN9510B, D8NN9510AA, D6NN9510A, and Holley P\N R4119, R7867, R8552. Center to center on the 2 mounting bolts is 2 11\16 inches
   / Ford 3000 New Carb, seems Governor isn't kicking in #6
Thoughts ? Thanks..
I think you need to get the directions to adjust the governor linkage on your tractor. You changed the length of the throttle rod and I think that's limiting your rpm.
I changed the length of the rod because the first go around I noticed at full throttle it had lower RPMs , thought by lengthening it would push more RPMs at full throttle. It didn't, the governor adjusts it right back. I also set it back to the same length it was originally today and tried that, but it also made no difference. Sure seems like no matter if I lengthen it or use the old length the governor over rides it. I ordered the shop manual, not sure if thats in there or not.
While I know the original carb had R411-1A and the other # stamped on it, I did wonder how to tell if the engine is
158 CID
175 CID
or 201 CID
Since I saw Ford 3000 cyl could be either of those.
I assume each of those requires a different carb , I just trusted what was stamped on the old one as the right part #.
float settings aren't something you need to adjust for rpm.. the float merely operates a valve letting fuel into the carb bowl.
I guess what I meant was when I manually pushed the float more open, it gave it more fuel and therefore more RMPs, was trying to figure out if there was a way to have it at full throttle and adjust that position so the float was opened wider at that point, giving more power. Which may not be the right/good thing, but it crossed my mind as a way to get more power/fuel than I was getting.
   / Ford 3000 New Carb, seems Governor isn't kicking in #10
I think i'd adjust a carb meant for a 3000 a lil richer if on a 4000 engine too.
soundguy
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2018 Toyota RAV4 SUV (A50324)
2018 Toyota RAV4...
2016 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2016 VOLVO VNL...
Vermeer Vac Trailer (A49461)
Vermeer Vac...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
MEGGER EZ THUMP (A50854)
MEGGER EZ THUMP...
