Ford 340B - Third Function Loader Help
   / Ford 340B - Third Function Loader Help #1
SixSpeed5
Dade City, Florida
Yanmar 359C, Kubota M135x/4630, Unimog, Deere 650/Ford 340B
Hey Guys,
I have a 1986 Ford 340B with a front end loader, I am wanting to modernize the tractor a little by converting the loader to quick attach, and I would like to to add a third function so I can use a grapple. I am a competent welder/fabricator, so the quick attach is no problem, but I am still learning hydraulics and what my best route might be. Any and all help would be greatly appreciated. As much as I would love to drop it off and pick it up with a third function, budget is tight so I will have to learn myself some hydraulics and DIY.
Tractor has an open center system, 22GPM. My current loader valve is in need of a rebuild, it has some miles (abuse) on it. I mainly am trying to figure out if I should have it rebuilt and modify the system for a third function, or if I should buy a valve like this one and plumb it into my system:
3 Spool 25 GPM Prince Joystick Loader Control Valve with Grapple 9 8217 | eBay
Does anyone know if there is a port available on the factory valve where I can add a single spool valve?
I don't mind having a separate lever for my grapple.
2023 JOHN DEERE 2032R LOT NUMBER 164 (A53084)
2023 JOHN DEERE...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A52472)
2008 V.E...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
Unused Delta Crash...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2015 TIGER MANUFACTURING  10"X12" PUMP (A52472)
2015 TIGER...
