I understand what your saying, but,....here's my thoughts, like I said, I also have a "thermostart" on my machine. The ignition switch tag burnt do to "overheating" which in turn burned the 15 amp fuse. No more "heat" in cold weather starting. Soooo, I re-wired the thermostart to a "starter button" type switch that has a higher amp rating than a toggle switch. The switch is connected to one of those small square relays, not a solenoid, the high amps go through the 40amp relay to the thermostart controlled by the relay via the low side of the relay. In our part of the country, -30 Celsius is a common thing in the winter, keeping the thermostart on for "30" seconds is common ( try keeping your cigarette lighter on for that amount of time) believe me, it does remove power from the battery, leaving the thermostart in the "on" position while turning over your engine "draws" the heat and lit fuel into the chambers for a better start, letting go of the switch will cause the thermostart to shut off, hence, no more burning hot fuel while cranking. It works well for me, anyways.
Tractor sitting for a day at 40 degrees isn't really a test to me, but I'm glad it worked out well "this" time for ya.:thumbsup:
