Ford 4.6l Electrolysis
   / Ford 4.6l Electrolysis #11
How does a anode work? By bolting a zinc block/wad/whatever-shape-it-is-in up to the frame. However you want to bolt it up is fine.
You need a liquid electrolyte (i.e water) to provide an electrical path between the the metal you want to save and the sacrificial anode. So you won't save a head by bolting an anode to the block or the chassis. If only it was that easy!
   / Ford 4.6l Electrolysis #12
Its a bit of a pain to go in and re-tighten the head bolts a month or two after installing a new or reconditioned engine but really thats the best way to prevent the damage described in the OP's first post.
   / Ford 4.6l Electrolysis #13
The tractor I just sold called for head bolt re torque at 50 hrs.
Chris
   / Ford 4.6l Electrolysis #14
In twenty years as a tech, I've never had to re-torque head bolts.
Railroad and industrial marine engines have re-torque specs but that is because some heads are so long in V16 applications and the defunct V20 (which had a tendency to twist crankshafts leading to an early retirement) applications.
Short heads should not need to be re-torqued. The longest head I ever encountered was Ford's 300 straight six and it has no re-torque spec.
That said, if a spec calls for re-torquing, do it.
Redline 1025 rpm, baby! The V20 engine in the video below is rated at 5000hp at 900 rpm. Maximum performance, industrial style.
HAMM H11 PADFOOT ROLLER (A58216)
HAMM H11 PADFOOT...
T/A Flatbed Trailer (A59230)
T/A Flatbed...
INSPECTION (A57454)
INSPECTION (A57454)
Fisher 1000 Salt Spreader (A55272)
Fisher 1000 Salt...
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
