Ford 445 backhoe no digging power
   / Ford 445 backhoe no digging power #11
If thats true then there wouldnt be any point in checking the filter/suction and possibly the relief.
   / Ford 445 backhoe no digging power #12
I fail to see where he says anything about loader function, good or bad. I always want to start with the basic things first. My day is full of guys that want to buy hydraulic pumps before filters and injection pumps before fuel filters and lift pumps. It is nuts. There is a logical path to troubleshooting, or should be.
Right now it痴 all down I知 waiting on a steering cylinder to arrive while I wait I will go ahead and replace the hydraulic filter. I have only haves this machine for a short while and I知 not sure when the filter was changed last. I am still looking for a gauge set to check the pressure . I will be back on it as soon as the cylinder gets here
Thanks Mark
   / Ford 445 backhoe no digging power #14
With the loader being strong, I would put my first guess (without testing) on the control valves. There are several O rings and other seals in the valves and they do start leaking over time
Ok guys finally got a Hydraulic Pressure Test Kit from eBay so my ? Now is where do I hook it up to test
.ebay.com/itm/Hydraulic-Pressure-Test-Kit-200031-/223341171396?txnId=2197079462012
   / Ford 445 backhoe no digging power #16
Hope others can advise but look on the pump and valve body, see if there are some pipe plugs (maybe 1/8 NPT)
I have a similar kit and had to make up other fittings to fit machinery
If unable to get enough info, try posting on Heavy Equipment Forum
anyone ?
Tested the pressure at the boom and getting 2150 with the michine idling. So now Im at a loss lol
   / Ford 445 backhoe no digging power #19
Move the gauge set to the dipper (crowd) cylinder and then to the bucket cylinder. Each swing cylinder would get checked also. It will take some time, but will be worth it in the end. Any one of the cylinders could be bypassing or you could have a valve section not working correctly. A little piece of trash will get hung up in the weirdest places (usually the one hardest to access)
Will do
20ft Driveway Entrance Gate w/ Horse Design (A57454)
20ft Driveway...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
Chisel Plow (A57454)
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
High Accuracy Meter Fuel Pump (A57453)
High Accuracy...
