Ford 445 industrial tractor lubes
   / Ford 445 industrial tractor lubes
I happen agree with RicKB.
If you can afford the tractor you can afford the manual.
Most of them are chock full of usefull information.
That said, Use any generic UTF that meets Ford 134D specs. It will say that on the label.
One oil to keep on hand for tranny, rear end, loader hydraulics and power steering.
Thank You
He just asked a question since he didn't have a full manual. Not that his response was warranted, it was not. This is the friendly tractor section isn't it?
Thank You
   / Ford 445 industrial tractor lubes #13
Thank you Rick B, once again! I was having a 3 point problem. I thought the transmission was common to the rear end. I went to my factory operators manual and there it was....how to check the rear end fluid. 5 gallons later and the 3 point works perfectly again. :ashamed: I just finished reading the entire OM and was surprised to find out all of the maintenance procedures were covered in good detail. I will be looking more closely at the items that have been neglected, as well as a complete service. Any bets on how long it's been since the loader hydraulic pump driveshaft has been greased? Yup, learned about that too! Thanks again, Rick B, for taking the time to share your knowledge on this forum.
   / Ford 445 industrial tractor lubes #14
you can get an owners manual off EBAY for 25 bucks, tells about tractor specs and maintenance schedules and fluids.
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
Brock 5 Ton Feed/Grain Tank (A55218)
Brock 5 Ton...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
