Ford 450 vs Ram 3500
   / Ford 450 vs Ram 3500 #51
Noticed some talk here about plastic interiors. My 08 Sierra SLT can't hold a candle to the creature comforts of my Dad's 1972 Delta 88. Just Plastic JUNK. Woudn't be so bad if the price reflected that. I suppose it has something to do with recycling. Glue some carpet onto a door panel and you've created a recycling issue!
I was at my mechanics lately who have no particular brand loyalty. As far as Diesels go, they said Ford is the most complicated, Dodge seems to have the best engine but said the Dodge won't drive down the road like my GMC. Apparently you fight to keep the Dodge goin in a straight line.
I'm kind of interested in that new Dodge 3 litre Diesel, especially if they put it in the Dakota.
They stopped making the Dakota a few years back.
   / Ford 450 vs Ram 3500 #53
Are you serious? Had two of them, a 94 and 2000. Loved them, but they loved fuel. Both 6 and 8 were about the same! I see so many of them so I never knew they were out of manufacture!
Should buy an old one and put a single cylinder Lister under the hood! Might need a hood scoop type of thing to accomodate the flywheel!
The small to mid size pickups stopped selling. As far as I know the only Amercan made would be the Colorado.
   / Ford 450 vs Ram 3500 #55
The 6.7L Ford does NOT hold up well in C&C applications.
   / Ford 450 vs Ram 3500 #57
What happens to them? are they cooking them? I have a good customer who is replacing 450's with 7.3's but the only engine I can get in a Terrastar is a International Max 7 and I know nothing about them. CJ
   / Ford 450 vs Ram 3500 #58
we have had horrible luck out of them since getting our first ones in mid 2010. Of the 13 we have, the first 9 blew the engines under 50K miles, 8 2011 models and one 2012 model.
Several have had injection pump/injector failures, all 13 have had multiple turbo failures. 3 have had transmission rebuilds under 50K miles. Boost tubes break so often that we all have a spare on our trucks. Now we are starting to see DEF pump failures and DPF/DOC failures that require replacement. My truck now has 90K miles on it.
The 6.7L I am referring to is the FORD 6.7L, its not an International/Navistar design but an in-house Ford design.
   / Ford 450 vs Ram 3500 #59
My 2007 Tundra was made in Princeton IN, now all the Tundras at the San Antonio TX plant. The 5.7 V8 is made in Huntsville AL.
   / Ford 450 vs Ram 3500 #60
Wow! With an experience factor you are having, its a wonder Ford is still in business. Just what is the application these trucks of yours are in?
What is even more amazing, after the first nine blew their motors at under 50k, you bought four more?
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
2017 Ford E-450 LP Handicapped Bus (A53422)
2017 Ford E-450 LP...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
