Ford 4500 hydraulic pump replacement.
   / Ford 4500 hydraulic pump replacement. #11
Thats valuable information, basically you're saying the pump can't fail from a blockage the pressure would release, is this correct? This would mean I can put in a new pump and not worry that it failing again because of a blockage or something like that.
Thank you
Dana
Not likely. If the drive shaft wiped out the bottom of the radiator, I suspect the driveshaft broke the pump shaft. If you weren't using the hydraulics excessively and it sounds like you weren't, then the oil is going to circulate in the system until you move a lever and bottom out a cylinder.
If you have a picture of the driveshaft, I might have pieces to salvage two for one with new cross kits.
New/Unused AGT Industrial LRT23 Mini Skid Steer Loader (A51573)
New/Unused AGT...
2018 TAKEUCHI TL10V2 SKID STEER (A51246)
2018 TAKEUCHI...
2008 Chevrolet Trailblazer SUV (A51694)
2008 Chevrolet...
2013 RAM 4500 (A50323)
RYOBI EASY START INVERTER GENERATOR (A51248)
RYOBI EASY START...
Woods 9204RD-2 Flexwing Finish Mower (A51573)
Woods 9204RD-2...
