ford 5000 engine identity
/ ford 5000 engine identity #1
stami
athens
FORD 5000 diesel 1976
Greetings new to the forum!
I own an english FORD 5000 diesel 1976 i have changed the original engine after two block cracks and i have placed propably a bsd engine around 85hp (6610 or 6640) the new engine has this two idenfication codes FO NN 6015-CB & HH3 4 A 06.
I know that FO means 1990 NN means Tractor Division 6015 means Engine Block Code but cant find anything for CB and HH3 4 A 06.
Any help please ?
Thanks japody for your reply but i am asking for the engine specs. My father replace the engine around '94-96 i am not sure if its a 6610 82hp genesis or a 6640 86hp powerstar
/ ford 5000 engine identity #4
The CB part number suffix means that there have been many changes to the original FONN-6015-A, followed by B,C, D, etc through Z, then AA, AB, AC .... AZ until the A cycle is completed, followed by the B cycle, then the C cycle until your CB change level. That is all the intelligence this knowledge affords.
Opti-Mist thanks!
I have the impression that 6015 -C means 1962 if i am not wrong.
Anyway thanks both of you.
/ ford 5000 engine identity #6
Part numbers do not correlate to the calendar save for the first two characters of the prefix (F0NN). The alpha suffix is simply a sequential indicator of changes to the original drawing.
As you say is just a sequential indicator of changes i agree,
/ ford 5000 engine identity #8
Stami, just found your post. The engine serial number, stamped into RH ledge or rib behind the bolster, starts with a letter, followed by 6 digits. The letter indicates the engine model. I don't have the code at hand.
Also, in your first post, 4A06 is the date code. Yours is January(A), 6th(6), 1994(4) build date.
ENGINE
4,4
HH3 4A06
FO NN 6015 CB
*5E4500637* 4B14
Genesis or Powerstar ?
TRACTOR
6B3
B276249 right side
6A21B
B70A21 left side
Can you decode please ?
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
30in. Pallet Forks and Frame Skid Steer Attachment (A59228)
30in. Pallet Forks...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
10in Digging Tooth Bucket Excavator Attachment (A60352)
10in Digging Tooth...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
