Ford 542 baler
   / Ford 542 baler
You can increase the bale chamber pressure. Yours may be too loose causing soft bales. Are the bales all soft? Or are the bales tight, but strings are loose?
I’ve tried increasing the bale chamber pressure to point of twine breaking. The one bale before the twine broke was tied a bit tighter but still not what I’d expect. I’m going to look into a possible timing issue tomorrow if I have time. I’ll have to pull it out of the barn to get good access to it. I’m in the middle of changing rear tires on one tractor and the other has the TR3 on at the moment.
Busy! But at least it’s not been raining today, unlike where you are I imagine if you’ve been on here so much today and not working?
   / Ford 542 baler #12
Torrential rains for close to a week now
   / Ford 542 baler #13
Southernspeed, what type of hay are you baling. Often first cutting grass hay will be on the soft side if it does not have a lot of stems. We had the same baler and the first cutting hay was never as tight as later cuttings. But that was due to the nature of the hay and not the baler. I see the same thing on short leafy hay in our older JD round baler. But once you get some stems whether orchard grass, fescue, clover, etc. the hay bales would get tighter.
But as others have suggested, check the timing. One other thing to look for and it may've already been mentioned is to look for some wedge shaped metal pieces along the side of the bale chamber. If I remember correctly there were either two or four along the sides of the bale chamber. They helped hold the hay once the plunger compacted it and kept the bales tighter. The manual should show how they are set.
Mind you it has been 40 years since I worked with that baler, but it was a solid machine and we baled thousands of bales every year with it. I also live in central VA W. Jones
   / Ford 542 baler
I was trying to square some second cut round bales. I do have those wedges in place and it does seem to pack it pretty tight but won’t pull the twine tight as it knots ( or so it seems)
The tied bales moving along from the chamber are firm but the twine is just hanging loose. If you pick the bale up, there’s 12-18 inches of daylight between your hand and the bale.
   / Ford 542 baler #15
Sounds to me like your twine discs aren't holding the twine securely, they do wear out after a while and primary tension has little do do with it. On the 575 NH I sold last year, they were adjustable via shim washers.
   / Ford 542 baler #16
Since you have knots, the needle lift, twine disks, bill hooks, and wipers are fine. Check the force for pulling twine out of the twine box. Should be 10 - 15 lbs minimum.
   / Ford 542 baler #17
In thinking about the route the twine took between the twine box and the needles on the underside of the baler, I seem to remember some tubing guides and tension plates on the side of the baler. As ZZ points out if there is no tension coming from the twine box the twine could flop around and be very loose.
   / Ford 542 baler
I checked that initially and then started increasing it to try to solve this issue but got to the point where it was breaking the twine so had to back it off.
Plenty of suggestions here to re-visit, hopefully I can get back on it in a few days, it's got a bit busy around here lately and the big storm the other night didn't help ..... chainsaw is earning it's keep right now!
   / Ford 542 baler #19
I had your problem on my New Holland 315 baler before changing to a higher strength better quality twine.
   / Ford 542 baler #20
I have twine in my large square baler from last year and have had several broken strings this year. It definitely weakens over time.
I already made the switch over from 440lb to 550lb to help with this issue.
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
10x16.5 Tire Assembly (A52748)
10x16.5 Tire...
12in Backhoe Bucket (A52748)
12in Backhoe...
