Ford 555b shuttle shift problem
/ Ford 555b shuttle shift problem #1
D Lavoy
Bancroft Ontario
Ford 555 b TLB
Hello, I would like to know if anyone else has had this shuttle shift problem with a 555 b Ford. When first started in warm weather the shuttle doesn't fully engage ,but after driving around on the level for 5 minutes does engage but is slow to engage ( helps to rev it 1500 ) when it does go in it is a very solid shift, if you have a situation were you can do some heavy pushing to warm the trans up to 120 - 150 degrees it will work perfect and very strong from then on, otherwise I found that if I put it in 4th gear, give it a rev until it engages then hold it against the torque until well warmed up I get the same effect, I have changed the oil and filter several times and am quite certain that the sump screen is clean, when warm it will fill the front bucket in 3rd gear, goes from forward to reverse instantly, but when left to cool down too far, it goes back to it's old ways. Any help would be greatly appreciated, Thank you D.L.
2024 Teagle Tomahawk 8500 (A63688)
2024 Teagle...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
