Yeee haaaa, SWMBO was out building a fireplace for a customer today, kids were out and about so I got too play with Lil.
It was COLD (at least to me) just above freezing and it made for a couple slow times trying to get the rubber lines back together.
When I started working I grabbed my little magnetic tray I had stuck the bolts in and set in the cab. It had filled with water and was a block of ice. Oppppppppps.
All in all it went well. Everything slid together and felt right, nothing extra broke, changed the oil again, filled the radiator and drove the welder golf cart down to power a battery charger. Nothing like trying to bleed fuel, get a diesel started in really cold (for this part of the country) weather.
Anyway, cranked her through a couple of 15 second cycles with the lines cracked off the output of the head. Tightened them up, Cranked through another couple 15 second cycles and the battery was dragging.
Took a break letting the charger recoup a bit on the battery, came back and about 5 seconds of cranking she hit.
Man, that was a nice feeling.
Ran her for about an hour or so this afternoon moving around some piles of clay and everything looked good each time I checked.
Have to top off oil and antifreeze next time I go to use her, and make sure I don't have other leaks or problems, but so far all indications are positive.
Thanks to all for the input and suggestions.
Need to spend some time looking at my PS pump with Hanna running and see if I can ID where I am loosing fluid on that side.
Hope it all works well, it is sure nice to have it running again, I know it is a mindgame thing but it bothers me when my equipment is not operational.
