I agree with you about injuries caused by other tractors and implements; and that there could be much fuss about a few SOS injuries/ deaths; etc. The Pinto gas tank; Audi engine mounts; Corvair IRS.
My angle on this was simply objecting to your suggestion that it was creep: you said you didn't believe that an SOS/ Power-Shift would jump into gear; you introduced gear tractors and the idea that that was different; you mentioned creep in HST.
Based on what I'm hearing/ reading, I don't think that an SOS creeps. I think it jumps into gear because either 1) the lever is physically moved by the tractor being jarred (as has happened with my JDs and my TD-8 dozer); or 2) the lever is moved by pressure changes as the tractor idles (as I thnk also happens with my JD).
I don't have much experience with Fords. I usually have JD because I the mechanic I know does JD and is willing to advise me when I have problems. If he'd been a Ford man, I'd probably own more Fords. I like any equipment that works reasonably well, doesn't leak too much hydraulic fluid, and can be repaired at a decent cost.
Nevertheless, I am going to stay away from an SOS units. Not because of the jumping into gear but because of the repair/ reliability issues. Just as I stay away from JD 10s.
If you simply don't believe that a tractor with hydro-assist can jump into gear, that's your opinion in the face of much info to the contrary.
Believe me though, the last thing I want is to make this an ad hominem argument. I'm just saying that there seems a reasonable case for "jump" vs "creep" and IMO applying "creep" to an SOS is Ford putting a positive spin on it.
Soundguy said:I don't know why you have to be so completely rude every time we have a disagreement and then beat that same old drum that I am not as old as you yada, yada, yada.
I don't have to be born in 1912 to know something about the titanic.
I'm not being nostalgic. People get hurt on farm equipment. it's happened before they had motors on them.. every make and brand.
I've never indicated that SOS was a good piece of machinere or idea for ford. in fact.. I've avoided owning one. .. However.. as a ford enthusiast.. I have tried to research their history, along with other ford products before and after the SOS legacy since i own some of those models.
Any piece of machinery can malfunction.. no argument there. However. this SOS death spree seems to be a mountain / molehill issue. I'd wager we are talking about some extremly limited numbers / deaths related to real SOS -jump-into-gear injuries, vs other related farm injuries.
I wonder how many people have been kille dby threshers? binders? drils? mowers? sawmills?
You don't see people walking the streets condeming bailers cause people go and do thing without safety on their mind and then get sucked in and killed.
I wonder how many people been wound up on pto shafts?
Most of my tractor manuals I can get my hands on say to shut the tractor down before dismounting. How many of us here do that? Would the person that got killed byt he sos tranny have not got run over if he had heeded a warning in a manual? .. or did he do like many of us and figure that small chance would be a safe one to take....
Now.. if you want to debate.. lets do so.. however.. why not leave the rudeness at home. And quit beating your chest about how much older and smarter yuo are than people wo weren't born when you were. That's just plain unprofesiional and doesn't add squatt to the discussion.
If those are the only 2 putdowns you know to use on me.. give them a rest.. or at least find some new way to insult me .. you know... something fresh. I'd insult you back by my parents raised me better than that.
Soundguy
