cdicksen
I posted this once before but still cant find the problem. My 655c shuts off intermittently like someone shut the key off.  When I go to restart there is no power to the key (verified with a test light and by the batt light/buzzer being off)But if you turn the hazard lights and directional signal on the battery light comes on along with the buzzer (but the machine won't turn over).  I shut everything down and eventually power is restored to the key, the machine starts and it runs fine.  I checked the wires and don't see anything loose but  I am going to check the main engine harness connectors under the floor for corrosion but since the problem is intermittent, I really don't think its the problem.  I also changed the start relay in the cab but I can pull that one out completely while running and the machine doesn't shut off. Anyone else have a similar problem or what about the fuel shut off selenoid on the injection pump? If that was going bad, would I loose power to the key?
