ford 660 tranny/pto help needed
   / ford 660 tranny/pto help needed #11
Oh good, John. Sounds like it was simple enough, huh? Thanks for posting up the fix, that's what makes this work!
   / ford 660 tranny/pto help needed #12
This clutch problem remind's me of a noise coming from rear when my tractor was driven forward or backwards. Strange thing was the noise was different depending on where I was at the time. Got a ton of information on how to split tractor and pull things apart in order to inspect clutch,transmission and differential along with several other possibilities. I was still assimilating information gathered when I looked down and there it was! A #2 Hunt's green bean can with some wire attached had become intangled on right rear wheel where it was hitting the ground on every revolution of wheel. The reason noise was different at times was due to surface being driven on. Concrete surface,gravel and dirt each sounded different.
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
UNUSED CFG NT18K EXCAVATOR (A51247)
UNUSED CFG NT18K...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
PumpJack Brand Pump Jack (A53472)
PumpJack Brand...
(5) PARTIALLY COMPLETED TRAILER RAMPS (A51247)
(5) PARTIALLY...
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
