A 70/50 Front/Rear ratio means that for every full rotation of the front tire, the rear tire will make slightly less than 3/4 of a turn(71%). I am just suggesting that a 29% front tire overrun might cause some performance issues and, perhaps, premature wear. Exact tire circumference can usually be found on the tire manufacturer's website. I have a formula that uses tire circumference to find the desired MFWD ratio, but you have to know both differential ratios. I will find and post it if anyone requests. The MFWD ratio will be stamped on the machine somewhere. It will either give you the number of teeth on each gear (example: 43/33) or a decimal equivalent (ex: 1.303). I like to keep front overrun as low as possible without going negative.
