BAP
- Joined
- Aug 23, 2013
- Messages
- 360
- Location
- Walpole, NH
- Tractor
- Kubota B2920 Loader, BH65, 60"MMM, B2782B snowblower, Forks , Woods 48" bush hog
Check your filters and make sure they have seated properly and the gasket has not come out of place. There should be a top gasket, a bottom gasket and a O-Ring for the bolt. As you tighten the filter, give a little turn to make sure it seats well. Lastly, go threw and double check all the lines you might have taken off and make sure they are tight and make sure the shutoff valve is opening all the way. When you bleed the filters, are you getting good fuel flow by gravity? You should have good flow out the bleeder if the top tank is full.
