Ford 8N Carb Problem
   / Ford 8N Carb Problem #11
Steve..The entire time it was probably a bit of grit in the seat of the float needle holding the float valve open.. letting her flood.
soundguy
   / Ford 8N Carb Problem #12
i found a 49 8n this past week has water coming out the exhaust and rear lift is weak other wise tractor is clean owner may sell since i now mow his pasture he said he might sell for 1500$
If you have water out the exhaust.. check the oil to see if there is any water in the oil.. and check the radiator for lots of oil init. a little oily sheen is ok.
Sometimes a wet stud will leak.. and if so, you can pull it, pucky it, and reinstall.
1500$ is good privce for a running N.. but I would not want to buy one with a cracked block.. etc.
Weak lift?.. could be excessive leaks.. or weak relief.... open the dipstick inspection port and lift a heavy load.. look in with flashlight and look for leaks up top.
Bottom line.. to completely R&R the 3pt lift with new gaskets and a ne wlift cyl and piston is about 200$.. with no cyl.. and just hone the old one.. about 100$.. should take about 8-9hours for a lift cover and pump rebuild as long as no parts in the pump other than the screw in relief valve need to be repalced.
get an I&T FO-4 service manual if you plan on doing this... EZ job more or less.. lift cover and pump each weight about 50#...
soundguy
   / Ford 8N Carb Problem #14
post back if you need any help on the hyds.
soundguy
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
2017 TRAILSTART 40FT DUMP TRAILER (A54607)
2017 TRAILSTART...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
CASE 580 (A47477)
CASE 580 (A47477)
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
