trentonford3000
Bronze Member
i always put implements down and i am pretty sure the manual says it will lift about 800 pounds a brush cutter is a good match
That's pretty normal. There may be a slight leak in the lift cylinder but if it akes 20-30 miutes to leak down, it's a small leak and hardly worth removing the lift cover. You an pull the sideplate and look for a leaking pressure relief valve but what your seeing is pretty normal.
So far everything I've read about these being a great tractor is true.
The more I use it the more I like it.
Thanks again.
