ford 8n power steering.
   / ford 8n power steering. #11
Not that hard from where I am sitting. I would pick a side. From there, make the link on the side have a ram on it. Bend/weld new arms to the king pins or run them off of the bottom or the hub like a vehicle. Cross over drag link from 1 side to the other and run your pump. May lose a bit of radius because of the lack of the inner circle not as tight, but still not bad. Just like a solid axle pickup.
SWS
   / ford 8n power steering. #12
still need a pump and orbital valve.., or a nifty valve in cyl setup
I'd like to have a manual back up incase the old girl breaks down. If its 100% hydraulic it would be had to steer if I was towing it.
   / ford 8n power steering. #15
most orbital valves incorporate a pump so you can reposition the wheels without engine running.
.. like when towing. etc..
not easy.. but it works..
Ooo okay that would work. Has anyone had luck with a Jackson unit?
   / ford 8n power steering. #17
i know i'm apparently being ignorred here, and only have about 20+ fords.. so not much experience... but i mentioned jackson back in post #3 .....
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
2015 PETERBILT 367 (A53843)
2015 PETERBILT 367...
2017 TOP HAT TRAILER 16 FOOT UTILITY TRAILER (A53843)
2017 TOP HAT...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
2015 New Holland Boomer 47 4WD Agricultural Utility Tractor (A53421)
2015 New Holland...
