53GMC
Bronze Member
- Joined
- Jan 14, 2012
- Messages
- 58
- Location
- Western North Carolina
- Tractor
- Ford 8n, Two Massey Ferguson 20 Industrial, Hinomoto
Hello everyone! I am new here at tractorbynet.
I have a 1952 ford 8n with a 6ft howes bush hog. (Yes, I know it is to big but it was dirt cheap :thumbsup:. It weights between 750-850lbs.
My tractor will lift the bush hog about 1 1/2 foot off the ground when cold, but after it warms up it has a hard time lifting the back wheel up in the air.
It also randomly sticks in the up position after it is hot with a Heavy load then will drop back down to where the lever is set to within a couple minutes
It works fine with all my other attachments witch are lighter but it will not lift the front wheels off the ground on flat ground with a boom pole.
The pump makes a slight knocking noise with a hevey load.
The lift arms will leak down without an attachment on them in less than an hour, faster with an attachment.
What should I do to correct this? It is still usable bit is not getting any better.
Thanks,
Philip
Thanks,
Philip
