Ford 8N sediment bowl Shut Off Valve
   / Ford 8N sediment bowl Shut Off Valve #1
carpediem4570
Edmonton, ab
MF65, Ford 8N, AC WF
I have a little Ford 8N. I was out discing a small patch for planting a garden. When I finished, I brought the tractor back to the house and went to shut the fuel off at the sediment bowl. Well, turns out the screw holding the turn handle to the bowl backed out and I lost the screw and the handle in the field. I am using a pair of pliers to turn the valve. Can anyone here tell me where I can get the little screw and circular handle that fits on the bowl?
Thanks in advance for your help.
Kind regards,
Carpediem
   / Ford 8N sediment bowl Shut Off Valve #2
Tractor Supply has a good many parts for an 8n. I got a new sediment bowl from them. Can't remember what else was in the box though.
   / Ford 8N sediment bowl Shut Off Valve #3
You will probably have to buy the whole assembly.
   / Ford 8N sediment bowl Shut Off Valve #4
   / Ford 8N sediment bowl Shut Off Valve #6
Looks like RickB found what you need.
Thanks folks for all the help. Will order my parts and put away the pliers.
Kind regards,
Carpediem
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55301)
2017 KINZE...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
UNUSED LANDHERO LDH-GAC40Y AIR COMPRESSOR (A54757)
UNUSED LANDHERO...
SARLO MOWER (A55758)
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
