Diamondpilot
Super Star Member
- Joined
- Jan 18, 2007
- Messages
- 16,316
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
I need help. I have a vintage 900 series Ford 961 Power Master Gas tractor. For some time the 3 point has only lifted maybe 6" so as you drive with a implement in the air it drags over rough terrain. I changed the fluid with Ford Spec 134 fluid from TSC with no change. The fluid I drained out looked very milky in color and was hoping this fluid change would fix it but did not.
I have read the operators manual I have and can not figure out what is going on. I have tried moving the draft lever and back to normal, the up position(horizontal), with no change. The tractor does have one single rear remote and from what I understand is that you pull the knob out in front of the seat where the hydro line goes back to the remote to divert fluid to it instead of the 3 point. Could this be the problem????? I have never used the remote and don't plan on using it.
Any help would be appreciated. I own a couple modern tractors and have a basic knowledge of tractors systems but I am lost with this one.
Chris
Chris
