Ford 907 flail 6'
   / Ford 907 flail 6' #1
Steve O
I have an old ford flail mower and the cross shaft bearing went out a couple of years ago i just got the time to fix. I used a mic on the bearing bracket and cross shaft and got 1.1635" on shaft and 2.800" hole size for flangette I'm trying to go to tsc for parts but want to know the size to get. Any input would help.
   / Ford 907 flail 6' #2
These open bearings like all bearings are metric in actual size,
you should plan on changing both flail rotor bearings as a matter
of principal and piece of mind for your mower.
If you look at the flailmaster catalog on line you should be able to find the bearing. I will check my catalog quickly and see if it is there now.
Edit
I found bearings for the 918H but not the 907. The folks at flailmaster would know what you want for sure if you call them on tuesday.
One of the other members here has manuals and can probably tell you which bearings you need for sure.
Welcome to our newest member of the Flail Mower Nation.
Only 17,997 mowers to go.
_________________________________________________________________
Once you go flail you never go backthumbsup::licking::drool:
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
Utility Trailer (A52377)
Utility Trailer...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
