ford 960 oil pressure question
   / ford 960 oil pressure question
sorry guys I dont know if he said head gasket or if that is just what i heard it was the valve cover gasket that went after he replaced the oil pump lots of oil to the top of motor
the line to the oil guage is not blocked almost no oil at the fitting where it attaches to the block blockage is in the block.
engine runs well no ill sounds at all
when i looked at it today the temp was about 20 deg started pretty well with a boost been sitting all winter.
rolled over 5 or 6 times before firing
two stage clutch works pedal has been adjusted up about 1.5 inches higher than normal position to make work
hydrolics work 3 pt raises and lowers seems to stay in up pos. no air or oil in radiator. head lights need some work but that is minor.
he replaced seals in power steering hyd ram
ahs adjustable fromt end and adjustable rear wheels
sorry i didnt get a pic for you guys scannr is notworking right.
forgot I think this is the serial no. 5668157 1 does this look right to any one
Im looking below air filter and in front of clutch
thanks
   / ford 960 oil pressure question #13
Here were the years and starting serial numbers:
Year Starting Serial Number
1954 1
1955 10615
1956 77271
1957 116368
You need to look on the flywheel housing,.. should have stamped 3 digit model number ( 960 ) and then the serial number.. which looks like it is going to be 6 digits or less...
Soundguy
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
New/Unused Gold Mountain Container Shelter 20ft x 40ft (A51573)
New/Unused Gold...
2021 JOHN DEERE 7R230 LOT NUMBER 208 (A53084)
2021 JOHN DEERE...
INOP/NON-RUNNING 2008 International 7300 Truck, VIN # 1HTWAAAN78J690166 (A51572)
INOP/NON-RUNNING...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
New/Unused Gold Mountain Container Shelter 20ft x 20ft (A51573)
New/Unused Gold...
