Ford 9600 trouble
   / Ford 9600 trouble #1
bentonfarm
My 9600 is not doing good, when I get in to move, put it in gear, and release clutch it sits there like it's not in gear, ok so I tried to raise the 3 pt hitch arms up and nothing, no PTO either. So I turned it off let it sit and checked hydro oil and it's good. What's wrong?? Thanks
   / Ford 9600 trouble #2
Stripped splines or sheared output shaft ?.....I've had 7600/7710 do it ,
   / Ford 9600 trouble #3
do you have any history with it? how long have you had it? What work has been done on it?
   / Ford 9600 trouble #4
+1. Stripped splines at the coupler bolted to the engine crankshaft and the shaft that engages it (or used to). Transmission must be completely removed to replace the shaft. Front (clutch) split first to confirm diagnosis.
   / Ford 9600 trouble #5
+2, but as an alternative to trans out and new shaft and coupler we used to machine a 3/4" socket into coupler and square nose of shaft to 3/4" in situ with grinder if cost is factor in repair. Have had tw's and 10 series run for years with this repair.
2019 John Deere 1025R (A46443)
2019 John Deere...
More info coming soon! (A44571)
More info coming...
2012 PARKER GOOSENECK (A47001)
2012 PARKER...
Bobcat 72in Skid Steer Snow Plow (A47809)
Bobcat 72in Skid...
18' Bi-Parting Gate (A46443)
18' Bi-Parting...
Mahindra eMax25 (A46443)
Mahindra eMax25...
