Ford 9N no spark, what am I missing?
   / Ford 9N no spark, what am I missing? #1
etpm
Veteran Member
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
The tractor worked great last year. I parked it and about 6 months later no spark. I cleaned the points. The condenser is good. I bought a new coil because the old one seemed to measure wrong with a meter. Still no spark. Even when I run a wire from the negative terminal directly to the coil. I'm stumped. Any ideas?
Thanks,
Eric
   / Ford 9N no spark, what am I missing? #2
I am assuming this is a front mount engine, check the spring that makes the connection from the coil to the points. In fact take the distributor off where you can get to it on the bench to clean, check all the connections and test for spark. Be much easier to see what you are doing. It will only fit one way (wide and narrow drive notches to match up) so there is no concern about messing up the timing or getting it back on correctly.
   / Ford 9N no spark, what am I missing? #4
You cleaned the points. Did you check the gap, too? Hooking twelve volts to the coil only gets a spark by connecting and disconnecting the wire. The coil is not strictly a direct current device. It depends on the points opening and closing to make a pulsing DC. The condenser serves to damp the spark across the points. If it's shorted you'll get no spark. If it's open you'll burn your points. You need to have some spark at the points to create the high voltage spark out of the coil.
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
Freighliner Tender Truck (A56438)
Freighliner Tender...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
