I called one of the better frame shops in town that also does utility bodies, or maybe I should say it the other way, a utility body shop that does frames. Anyway, they swear I won't have to cut the frame but I pressed them to give me a price "in case the frame needed to be cut". I also called a couple of the local auto dismantlers (hey, trying to get politically correct with that) and even one of the local junk yards. (Yep, one wants to be called a junkyard) for pricing and availability of a dually bed from that era. Found two so far and they are 1500 to 1750 dollars.
The width of the frame rails isn't a problem with a Chevy truck, and since I am not familiar with how Ford mounts them, I can't say if it will be a problem or not, but even if it requires hanging a couple of side mounts to the frame rails with a stabilizer crossmember in between, that shouldn't be a big deal. The biggest problem is if the frame sits higher on the cab/chasis. I will put a tape measure on it as soon as I can, you can bet on that!
Since this truck actually never existed, I realize I am going to have to make some changes to what I end up with. I was about ready to give it up since the seller hadn't replied to me (auction) and the auction ended without it being sold (I was high bidder).
I have a couple of different avenues that I can take. One would be to buy two beds and have the front end of one extended with the metal from the second. That covers all the bases of wheel position and the cab to bed gap. However, if the frame is higher as it appeared with Mr.Jimi's truck, then cutting and dropping the frame at the rear of the cab will probably be my route due to not wanting the problems of a cab lift. Before I actually cut the frame I will probably investigate having someone do a cab lift, but due to my work schedules, I won't be doing this.
The bottom line, depending on just what truck I end up with (*since seller hasn't been jumping thru hoops to contact me) and the original sale of an F350 dually from a friend has been put off indefinitely, will determine just what modifications I make to the truck.
An F450 with a longer wheelbase could turn out to be a p/u with a 9 or 10 foot p/u bed. One of the main reasons for that would be in case I come across an extended or crew cab later in life and wanted to change out the cab to give me more room. (this one is a regular cab) Or I could have a F450 with a standard bed, with the cab lifted a couple of inches, which isn't my preference, since climbing in and out of a vehicle should never require a step ladder. The last thing, which would drive the wife crazy would be for me to build a flatbed for it and drive it that way. She hates a work truck appearence and won't like it. However, should the p/u body become a major hassle, it is one that I can fall back on so that I don't complete throw away a big chunk of money.
Anyone know just what kind of fuel mileage those F450 trucks with 488:1 rear ends in them get? I am not expecting much, especially after Soundguy mentioned that it isn't great...just thought somebody might have an idea.
More to come if the seller decides he actually wants to sell his truck.
David from jax
