Ford Golden Jubilee Battery
   / Ford Golden Jubilee Battery #1
BrackDempsey
Ford Golden Jubilee
I have a Ford Golden Jubilee that was a gift from my uncle before he passed away. I am not an experienced tractor owner, so I watch a lot of videos online to learn how to repair it (to give context of my knowledge of tractors). Is there any way for me to determine whether it has the original 6 volt battery system or if it was modified with a 12 volt system without looking at the battery? Unfortunately, the last working battery is not available.
   / Ford Golden Jubilee Battery #2
Brack without assuming to much you should be able to see if the voltage regulator is still hooked up. And if it’s visible it be marked somewhere. Also if it has an alternator you could safely assume it’s 12 volt. You are smart by checking this out, the devices work best at their rated voltage. I still have one of those machines and it’s still 6 volt and will be long as I own it
   / Ford Golden Jubilee Battery #3
Pictures of the charging system that is currently on it would help us identify what you have.
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53472)
2020 New Holland...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
CAT Skid Steer (A50322)
CAT Skid Steer...
Suzuki Kingquad ATV (A51694)
Suzuki Kingquad...
