Ford LGT Crawler Conversion
   / Ford LGT Crawler Conversion
Down off the table. went down the ramps in a very controlled fashion. No scary moments. I regret not moving the brake pedal to the other side earlier, it's in an awkward spot. Moves Forward at a brisk pace. Reverse is harder because the linkage is still out of whack a bit. Haven't tried to push anything with it yet, That will take time, need to move everything (boat, tractor, dirt bike, dirt bike, tractor, tractor barbecue) to get it in the yard. Also I have to put my bike up on the table, I have a new seat coming and the clutch is stuck.
It howls while turning, more left than right. I know the transaxle needs work, I'm in the market for a Peerless 2500/Eaton 11 combo I can rebuild..
I need stronger brake levers. the 1/2" rods tend to bend too much. It turns fine, no indication of the tracks trying to jump off.
It has a nice controllable feel when it goes over center.
Once I remember how to get vids off of the camcorder, I'll upload the vid I did of it crawling down.
Small embareassment, apparently, I was too excited about hopping on and driving, I didn't notice the rippers had hooked the bottom of the ramp coming down. I dragged the ramps and table 6 feet out the door, I didn't even notice it pulling.
Anything new with her??
I picked up another transaxle and checked it out thoroughly. I had to replace two bearings and two seals on the axles. Everything in it looks good.
As soon as I can get some time, I'll swap out the transaxle and hydro pump
   / Ford LGT Crawler Conversion #66
What happened??? Did the rear end give out??
My original transaxle was in pretty rough shape. The left side gears in the differential are piled up and it needs a lot of bearings and seals. It worked great as a wheeled tractor, but binds up on left turns
I've got the new transaxle in, and am getting the brakes set up. I still need to cope with the leaky fuel tank.
   / Ford LGT Crawler Conversion #69
Good luck with it
   / Ford LGT Crawler Conversion #70
Double post
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
2020 Am-Tank 800 Gallon Fuel Tank, S/N 73348, Nominal Capacity 838 Gallon/3172 Liter w/Spill (A59076)
2020 Am-Tank 800...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
