Ford New Holland 1920
   / Ford New Holland 1920 #1
RobertBrown
Florida
Bolens G192/TS1910 Ford/New Holland 1920
I'm about to purchase a 2wd 1920 built in the 3rd quarter of 1998 with a GB240 loader, 940 hrs. great tires (95% Firestones on the rear). I negotiated the price to 9700.00$ The sheet metal is almost like new and everything apears to be in excellent condition.
I neglected to look for a differential lock when giviing this machine the once over and trying to determine it's worth. I think it will be handy to have considering the 2wd and fel. Does anybody know if this machine indeed has a differential lock?
Thank for help
   / Ford New Holland 1920 #2
My 4wd 1920 did indeed have a diffy lock. i used it way more than the 4wd.
I paid 9500$ for a 1997 model, 4wd, 4x12 trans... no loader. I think you are getting a good machine. I'd have traded 4x4 for a loader.. like I said.. i used 4x4 exactly 2 times.. once while discing.. and once when i got stuck .. and the 4wd dind't help me get unstuck.. it got me stuck worse!
soundguy
Thanks for the input soundguy. I've been rewting around the site this week and I was hoping you would respond.
I'm really looking forward to picking up that machine this weekend. Ive got to drive from Hillsborough county to Lafayette county (3-1/2 hrs) but it will be worth it.
I've been using an Iseki for three years now. It's done a fine job but it's a parts nightmare. I've been keeping my fingers crossed. I'll be taking it to the auction next month.
Thanks again,
look for some pictures next week
RB
   / Ford New Holland 1920 #4
Robert,
I don't have personal hands on experience with 1920. It is big brother to my 1700 but a bit heavier and a bit more displacement. 1920 is 3 cylinder vs 2 for 1700. I have looked at it from close and component wise it is almost identical with 1700 except injector pump. I found 1700 to be a great little tractor and very capable coupled with excellent basic design. it is a no frill tractor but very easy to perform a lot of maintenance yourself if you are a bit hands on. I had never any problems acquiring parts from NH and most of the 3 point lift components are shared between 1700 and 1900 series. Having a loader certainly is big advantage. I have seen 1920 sale price any where from 8k to 13 k with front wheel assist. 2 wheel drive bring a lower price by 2-3k. If mechanically sound then it is not a bad deal. You can also find a late model TC-30 about the same price.
JC,
JC, Thanks for the input.
You may be surprised, as I was when I noticed that this model ford has a 4 cylinder engine. Seems like a 3 would have been plenty to produce the 32 hp that the specs boast.
I have a New Holland dealer within 3 miles from work that has a website with an on line parts catalogue complete with every expoded view you can think of. That and a shop manual should enable me to fix just about anything that goes arwy.
Hopefully I'll never have to visit the dealer but it's nice to know thier close.
   / Ford New Holland 1920 #6
Robert is correct.. the 1920 is a 4cyl.. and I liked the way it sounded and ran ALOT better than a tc33 that sat on the lot next to it.
soundguy
   / Ford New Holland 1920 #7
soundguy
My bad. I looked at specs on 1910 which is 3 cylinder. Tractor Data did not have a listing for 1920. Since I don't have a good point of reference my ole clanky 2 cylinder sounds good to me too.
JC,:)
   / Ford New Holland 1920 #8
I like 2-cyl machines.. but compairing them to 3 or 4 cyl.. the 2 bangers really hammer.
Also.. Tractor data does have the 1920 listed
TractorData.com - Ford-New Holland 1920 tractor data
General tractor information:
Manufacturer: Ford-New Holland
Model: 1920
Type: Farm/Agricultural tractor
Series: Twenty series compacts
Years produced: 1987 - 2000
Total built:
Factory:
Original price: $15,500 (2000)
Replaced: Ford-New Holland 1910
Tractor power:
Engine: 32 hp [23.9 kW]
PTO (rated): 29 hp [21.6 kW]
Engine:
Manufacturer: Shibaura
Fuel: diesel
Cylinders: 4
Bore/Stroke:
Displacement: 122 ci [2.0 L]
Compression:
Rated RPMs:
Cooling: liquid
Torque:
Firing order:
Transmission:
Type:
Forward: 12
Reverse: 4
Transmission:
Type: shuttle
Forward: 12
Reverse: 12
Mechanical:
MFWD: optional
Steering:
Brakes:
Capacity:
Fuel: 9.8 gal [37 L]
Coolant: 5.9 qts [5.6 L]
3-Point Hitch:
Rear Hitch Category: I
Rear lift: 2,185 lbs [991 kg]
Power Take-off (PTO):
Rear PTO: transmission
live (optional)
Rear speed (RPM): 540
Hydraulics:
Type: open
Capacity: 30.7 gal [116 L]
Total flow:
Outlet flow: 7.8 gpm [29.5 lpm]
Pressure:
Outlets:
Tires:
Ag front: 5.50-16
Ag rear: 13.6-24
Dimensions:
Weight: 3,300 lbs [1496 kg] (4WD)
Wheelbase: 69.9 inches [177 cm]
soundguy
   / Ford New Holland 1920 #9
Wow, That's heck of lot more machine that I got it figured for. Soundguy, I'm glad you're here keeping the info sieved and factual. Thanks:) :)
JC,
   / Ford New Holland 1920 #10
I cheated...I used to own one a few ys ago.... so that one I'm a little more familiar with.. Eventually traded it back in to the dealer I bought it from a few ys before that, and got my 7610s.. so i could mow faster...
soundguy
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A49346)
2025 Kivel 48in...
2000 TRAIL KING  RGN / TK60MG-482 (A48992)
2000 TRAIL KING...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A48837)
New/Unused 30ft x...
2022 FORD F-150(INOPERABLE) (A48992)
2022 FORD...
SICKER ROD W/PIPE RACKS (A48992)
SICKER ROD W/PIPE...
