Ford Raptor- anybody have one?
   / Ford Raptor- anybody have one? #51
GM has ruled the marine market go awhile. The are cost effective. Years ago it was Ford and before that it was Mopar. Some high end boats still have Fords and some really high end stuff has Toyota.
I still consider the 6.2 a small block.
Chris
GM has ruled the marine market for about 35-40 years now, they owned all the speed records for useable boats. I say owned, because I've been out of touch with the scene for 10 years. The BBC made more power inch for inch than the Hemi in a non boosted application and would live better, the Fords were not even close giving up 30-50 h.p. in any liveable combination. At one time I ran Hemi's in my '68 GTX as well as my flat bottom boat, but reality is what it is. And today "High end" or otherwise the LSx motors are are making more power cheaper than Toyota and Ford. I don't know what brand of boat is using either of those engines but I'll build you a 500 cu in LSx that will outrun and outlive it.:D
   / Ford Raptor- anybody have one? #52
Chris
I also consider it a small block...It looks no different than a 5.3...It just has much more go power all the way around....I personally like the big blocks but if an SB can crank it out, I'll take it...And it does.
   / Ford Raptor- anybody have one? #53
The 6.2 is becoming the choice for drag racers around here. Quickly becoming as popular as the 4 bolt main 350. With very mild upgrades, like a cam and head porting, in a mid size car like a camaro or nova, low 11 to high 10 second 1/4 mile times are the average. These LS motors make great power, especially with turbos. They remind me of the Hemi from the 60s, make good power stock and does not take much to really wake them up. Especially the 6.2.
   / Ford Raptor- anybody have one? #54
The naturally aspirated 7.0 (427) in the Z06 makes 505 h.p. by the more stringent newer rating from SAE J1349. GM was the first to volunteer to use the system the others waited until it was mandatory. By the way Chevy only planned to rate it at 500 h.p.' but SAE said no, the number has to be accurate as tested, so 505 it is. Not bad for an easily drivable push rod "old tech" as some like to call it when it whips their ohc motors. :D
   / Ford Raptor- anybody have one? #55
50+ year old tech and still rather easy to work on. I am not a big fan of modular or ohc motors. Pain to work on and have very tight tolerances, especially Ford.
   / Ford Raptor- anybody have one? #56
If it runs that good, I wonder if it will be regulated to death like the 426 series Hemi's. Nobody in large circle track or drag racing could keep up with the 426 series Hemi till it was heavily restricted... That motor was the first restrictor plate motor.
   / Ford Raptor- anybody have one? #57
I have had several Ski Nautique inboard ski boats. All my boats had 351 Ford based Pleasurecraft marine engines. The last boats had the GT40 rated from 300-310 hp. They stopped using Ford engines because the 351 was not being built and had been replaced by the OHC modular engines. These engines were wider than the 351's and wouldn't easily fit in the boats. The new engines are all built by GM.
   / Ford Raptor- anybody have one? #58
It is a very capable engine. I towed 10k lbs + over 300 mile round trip and was impressed. Averaged 8.8 mpg. I won't go as far to say it would walk away from the other trucks. The 3/4 ton GMC with the 6.2 pulled the same weight as I was and got a little better mileage, around 9.3.
Is that about normal for these? It doesn't seem like 8.8 is all that great.
   / Ford Raptor- anybody have one? #59
While the 6.2 may LOOK like a 5.3 the towing power is night and day between the two. The 5.3 I owned was not a very good tower, it was a screamer to be honest, loved to have the crap revved out of it. The 6.2 is a totally different animal. I've towed 8,500 lbs with mine and while my 5.3 would have felt like it was going to blow up, the 6.2 just chugs along nice and smooth. I don'tg plan on modding mine or anything like that, perhaps a blackbear tune years down the road when the warranty runs out. the surprising thing though is the gas mileage of the 6.2 BETTERS my 2004 Z71 averaging mid 17's. sometimes it'll hit 18, on a road trip once it was bumping 20 (19.6). my 5.3 would get 16 mpg whether driving in town, interstate, driving like a grandma or a race car driver, towing, not towing, uphill, downhill, wind behind me, wind in my face, no matter what it ALWAYS got 16 mpg....give or take a few tenths.
   / Ford Raptor- anybody have one? #60
Comparing an 04 5.3 to a 11 or 12 is tough. With the new trans, it is completely different. I had an 05 Z71 with the 5.3 and understand exactly what you experienced with your 04. My 2011 5.3 Z71 tows like a dream. No high rpms or excessive revs.
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
20ft Driveway Entrance Gate w/ Deer Design (A57454)
20ft Driveway...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
200 Gallon Tank (A57148)
200 Gallon Tank...
