ford Tractor 1972 gas 3 cyl.
   / ford Tractor 1972 gas 3 cyl. #11
Runs on starter fluid means lack of fuel
Took plugs out to chesk spark again they were blue and strong, added gas to celenders buttoned things up ,turned key and it started .it ran for 2 min. then stopped. sprayer started fluid around intake and carb but it had no effect. do you think the carb. is shot
   / ford Tractor 1972 gas 3 cyl. #13
or needs rebuilding... or the fuel pump is bad.. or screens are clogged.
if you can start her and keep her running on start fluid sprayed into the carb mouth then you deffinately have a fuel delivery problem.
that's surely what it sounds like.
going to try rebuilding again , THANKS GUYS FOR YOUR HELP let you know what happens. don
   / ford Tractor 1972 gas 3 cyl. #15
them holley are finicky
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2003 Ford F-350 Dump , VIN # 1FDWW36P63EC81092 (A51572)
2003 Ford F-350...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2024 JOHN DEERE 461M LOT NUMBER 62 (A53084)
2024 JOHN DEERE...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
