Forget bagging, go muching
   / Forget bagging, go muching #11
Beacuse I mow commercially and some of the customers insist on the clippings being hauled off. /forums/images/graemlins/crazy.gif
   / Forget bagging, go muching #12
No, those instructions work for the commerical and older 48'' and normal 54'' Deere mowers. The 42'' EDGE mower does not have rotatable gauge wheels on it. All of the gauge wheels will rotate into a service position so it can be slid out from underneath the tractor. You have to rotate the wheel by first pulling the spring pin or pulling out the pin and hairpin then you will see a hole in the opposite way to rotate the wheel. I have seen 48'' decks with round supports for the gauge wheels and flat bar type which you have so then you are right about no service position for you. I have the round type at home and that is what some come with. If your has the flat bar type then you just have to slide the mower on the wheels. My 48'' decks are from 1994 and 1996 and they have the turnable wheels for service.
   / Forget bagging, go muching #13
Trouble,
Was your cutting hight dial set to 0 or the lowest setting when you lowered the deck?
Yellow,
Yes, just as the manual tells to do. FWIW, it's the 54C deck. and it juuust barely fits out from between the wheels trying to slide it sideways. I 'reclaimed' about 1/4 acre the other day which was overgrown with some sort of swamp grass type plants. Really really thick tall grass near near a little pond on my land and though it was tough going and I sure shouldn't have done it with the muching setup, it went better than I could have hoped. The mice and frogs aren't happy but the crows are out having a field day today /forums/images/graemlins/smile.gif
-Trouble
2022 Bobcat T770 Skidloader (RIDE AND DRIVE) (A50774)
2022 Bobcat T770...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52748)
John Deere 1110...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
