Buying Advice Forks foe BX25d
   / Forks foe BX25d #12
Holy smokes, do those ever push the lift points far way from the pins! I wonder what the lift capacity is with that setup?
Not really. Measured the change in the pin locations on my QA and I think it's 3" or 3.5", can't recall exactly. If you see the Kubota QA in person you realize they did as good a job as they could to minimize the movement of the pin location. I really didn't notice much change in my FEL capability after getting the QA. Moved a lot of snow and other material with no issues. I did recently check and adjust the pressure on my BX25 to a bit over spec just "in case". I don't have the forks (yet at least) so I can't comment on what impact it has on their capability, but you can't use the Kubota forks without the QA so it would be moot anyway.
ru499 - nice pic's. Thanks for posting them. Forks are on my "want" list for sure.
   / Forks foe BX25d
I think I've probably used the forks as much as the front bucket! Great for picking up brush.
   / Forks foe BX25d #14
Now all you need is the Landpride grapple! Great for picking up brush. :D
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
KOMATSU PC150-5 EXCAVATOR (A51246)
KOMATSU PC150-5...
2016 FREIGHTLINER M2 WATER TRUCK (A51247)
2016 FREIGHTLINER...
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A53117)
2018 Mack PINNACLE...
2012 Bobcat T870 (A50123)
2012 Bobcat T870...
