Forl lift forks
   / Forl lift forks #1
Louisiana_John
Louisiana
65-56 HesstonMFD,FEL,Kubota 7040 cab/4wd, Kubota mx5000 4wd, 99 Cat D4C LGP, Deere 120C. Roller, Mini X, Deere 770 Grader,
He are some forks I but for my tractor a while ago. They have 3/8 plates up top for the forks and 4 channel for the rest. I have 1 1/4" rolled steel across the top of the bucket for support and the hook point. In the pick I have a load of rocks heading to our flowerbeds. This load is 2600lbs. I have pick up more. If I try to pick up to much more than this I have to use my 7' disk for ballast.
John [image]
[/image]
   / Forl lift forks #2
You might want to check that right front tire for air pressure. Looks a bit low. /forums/images/graemlins/smile.gif
2600 lbs is impressive. What did you use for the forks? I'm thinking about building some for my little tractor, but they will be used to lift far lighter stuff than you show in the picture. Mostly building material such as plywood and siding and an occasional log.
Tom
   / Forl lift forks
</font><font color="blue" class="small">( You might want to check that right front tire for air pressure. Looks a bit low.
)</font>
I am sure it does with that much weight on soft ground. I will check thanks. I will be using it more on Saturday. I am going back up to Arkansas to get about 14,000 pounds more of rock. Some creek stonds,flag stone, and big rocks. This will bee my 2nd load. The first was 14,427 pounds. We have been building bed all over.
Back to the forks. The forks are made of 4" channel,When I welded the fork to the riser I used a 7018 rod and went around both sides. The hook plates up top are 3/8 plate. I have no clue as to what the most I picked up was. I just know I had to use a lot of weight on the back. That is why the tires looked low I just had my 7' Box blade on the back. For quick weight on the back I strap 2 55gal drums on the blade and fill with water.
John
   / Forl lift forks #4
Post some pic's of your stone projects in the "projects" section John. I'd be interested to see what you're doing.
We've built a few raised beds around here.
   / Forl lift forks
I will take some tonight.
John
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2013 John Deere Gator 825E (A51573)
2013 John Deere...
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
2021 Chevrolet Silverado 4500HD / Silverado 5500HD Flat Bed, VIN # 1HTKJPVK3MH814615 (A51572)
2021 Chevrolet...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
