Foton 254: Gear shift block found full of water, should it be oil filled?
   / Foton 254: Gear shift block found full of water, should it be oil filled? #1
D0TC0M
NB, Canada
Foton TE254A
On my tractor I have the shuttle shift option. I took the 1-4 gear shift lever off and removed the top cover of the shift box (located on the right side of the transmission and also has the High/Low range lever too) and I was it half full of stinking water. I assume the water got in over time because the rubber boot has a small tear on it. I removed and cleaned everything out. It doesn't say in the service manual or I couldn't find if this box should be oil filled so I filled it 3/4 full with gear oil. Shifted alright before and it shifts smoother now.
   / Foton 254: Gear shift block found full of water, should it be oil filled? #2
You might find that you have overfilled it - I did on my Jinma. Leaks a small amount of oil around the shifter boot is all - rustproofing on the go!
Hi jim,
I filled it so it just covers the socket that the ball end of the shift lever inserts into.
DC
2020 EZGO GOLF CART (A50324)
2020 EZGO GOLF...
10' Unused Feed Bunk (A50515)
10' Unused Feed...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
