Found a spring tooth harrow on my property. need help
   / Found a spring tooth harrow on my property. need help #1
Rackluster
I just bought some hunting land and found an old harrow on my property. I know nothing about these things. I've only used 3 point attachments. How can I make this thing usable? Not sure how to hook it up???? I feel REALLY stupid.
anyway, i almost tripped on this thing as i was looking at the area i'm going to make into a food plot. apparently someone else had the same idea long ago. kind of funny.
my tractor is a john deer 950 (mfwd) which is about 30 hp. i'm assuming i'll have enough power to pull it?
thanks all
   / Found a spring tooth harrow on my property. need help #2
It would appear that is a clamp-on attachment that clamps onto the frame of a field cultivator (or disk, disc-harrow, or othere such implement).
The field cultivator does a nice job of working up ground in spring, and a 3-bar harrow like that added on to the back really made a nice smooth seed bed in one pass.
Today thosr harrows are a part of a new field cultivator. Back 40 uears ago, it was a new idea and the harrow part was often a bolt-on deal like this made by a different company as an add-on.
One way to use it would be to build a 3t tool bar, often 2x4 inch steel tube or 4x4 would work with the clamps, and clamp it on to that.
As is, the harrow would never work with a tractor alone, it was meant to bolt onto the back of a field cultivator frame.
--->Paul
thanks! wish there was an easier way to put it to use. might have to find a home for it on craigslist.
   / Found a spring tooth harrow on my property. need help #5
With a little modification you could add it to your 3 point disk! If you have one that is.
   / Found a spring tooth harrow on my property. need help #6
No reason you couldn't build a 3 point hitch on the front end.
Or a 2-inch square tube on the front to plug into your 3-point-hitch-to-receiver adapter.
hitch adapter
Bruce
2016 MORBARK BOXER 525DX STAND ON SKID STEER (A51406)
2016 MORBARK BOXER...
19088 (A55758)
19088 (A55758)
AUTO REWIND 12V HOSE REEL (A54756)
AUTO REWIND 12V...
2013 TAKEUCHI TB180FR EXCAVATOR (A52705)
2013 TAKEUCHI...
(APPROX 40) 1" X 2" X 8' - 10' ROUGH CUT PINE (A54756)
(APPROX 40) 1" X...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 78"...
