mikehaugen
Elite Member
Okay... so this isn't a tractor question but... I am changing the steering box on my sister's '04 grand cherokee and to get to the mounting bolts I need to remove the washer fluid tank, but to do that I need the get the sway bar out of the way. I thought I would just remove the mounting bolt for the bushing brackets, but that's where the problem is.
I got three out and the fourth came out about three turns then got stuck. I was using an impact and it broke loose the "nut" that seems like it was welded inside the frame. So now the bolt is loose and spins freely. I can't tighten or loosen it. The frame is boxed so I can't do much. Any suggestions?
Also, does anyone know if the front of the frame tubes are open? If I pull the bumper off, I can probably reach it. Then I could just cut the bolt and put a real nut on the inside of the frame. I may just weld the bracket on if I have to.
