Framing a house: 2X4 vs 2X6
   / Framing a house: 2X4 vs 2X6 #61
What if there actually is a kiln and grade stamp on it and I cut the board in lengths that don't have the stamp on it. Is that an illegal stud? What if I cut up some longer dried and graded boards to use as headers for doors or windows, no stamp left.
In my state, any piece showing has to have a visible stamp, even if that means some lumber gets wasted.
The questions is, for stuff like interior walls, when does it get inspected? I've heard of people getting the framing inspection done after the drywall is up, but it might have been only for a remodel. One of the common dodges is to have only the exposed lumber used to form the rough openings be graded, and anything under the rock might or might not be. All depends on your local department, I guess, and if you're asking questions, they may insist on seeing it before you hang the wallboard.
   / Framing a house: 2X4 vs 2X6 #62
I think it is the state of Mississippi that has no building codes or code enforcement personnel and only one city Jackson has any type code inspection and enforcement. So one could use anything or any type lumber to construct a home or business.
   / Framing a house: 2X4 vs 2X6 #63
In Michigan, my experience has been the rough framing must be inspected before any drywall is put up.
   / Framing a house: 2X4 vs 2X6 #64
Maybe your next question should be, "Where can I get one of them there stamp maker thingies?"
   / Framing a house: 2X4 vs 2X6 #65
If you are the mfg it appears that you make your own stamp.
Just like making helmets, "you" put "DOT" on it, no one is checking
unless there is an issue, then NHTSA could get involved but you
need no license and no one is watching what you make ...
So make your own rubber stamp! Easy!
From HERE I see this;
Then in another place I saw;
Then from HERE I find the good stuff ;
Grade Stamps
Because structural timber has assigned design values building codes and other regulatory agencies require structural timber products be clearly marked with an approved, registered grade stamp.
Most grade stamps, except those for heavy members, contain the following five basic elements:
1. Certification Mark
The ALSC-certified grading agency痴 registered mark. Attests to quality control supervision.
2. Mill Identification
Reveals the manufacturing mill痴 identity. It may be a name or assigned mill number. Grading agencies may be contacted to identify an individual mill whenever necessary.
3. Grade Designation
Grade name, number or abbreviation.
4. Species Identification
Indicates species by individual species or species combination.
5. Moisture Content & How Seasoned
Indicates the moisture content/condition of seasoning when timber was surfaced at the mill (KD indicates kiln dried):
   / Framing a house: 2X4 vs 2X6 #66
PS, verify what your local is using first, bring in a smple for approval
then cut away...
   / Framing a house: 2X4 vs 2X6 #67
Sorry, I cant comment on the stamping and code.
But I just wanted to post again because I accidentally clicked "unsubscribe" on this thread
   / Framing a house: 2X4 vs 2X6 #68
And I need to get the post count up:D
   / Framing a house: 2X4 vs 2X6 #69
Not to HJ the thread, but you may want to check with your home owner's insurance provider and make sure they will insure a new construction with rough cut lumber and that they won't increase your premiums for it. Just an issue I've seen in a few areas of the country since no insurance = no loan.
   / Framing a house: 2X4 vs 2X6 #70
2007 International 4300 Cab and Chassis Truck (A51692)
2007 International...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2006 Lexus ES 330 Sedan (A51694)
2006 Lexus ES 330...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
