Freeing a seized engine with compressed air
   / Freeing a seized engine with compressed air #1
09112
N.E. Oklahoma
yanmar 3810, 48 Allis B
I've seen several items on the web that recommend the use of compressed air to free a seized engine. Can anyone tell me if there is a fitting that can be purchased for such a method? And how about the down side, can there be a danger to life or limb? I would be interested in hearing from anyone that has actually used compressed air.
   / Freeing a seized engine with compressed air #2
I believe that you can purchase a fitting that screws into the spark plug port. Problem is that the valves have to be closed for this work.
Danger is suddenly moving parts and potentially no lubrication on any of the bearings.
   / Freeing a seized engine with compressed air #3
I've seen a few seized engines and doubt that compressed air would free them up. Usually an engine seizes due to water that got inside and rusted the rings to the cylinder walls or lack of oil that causes the bearings to seize to cam, crank, etc.
oldnslo is correct that compression tester hoses can be adapted to attach a compressed air line but vales must be closed and if air does push the piston down the valves will start to open defeating the purpose.
IMO a seized engine needs to be taken apart to see why it seized and what needs to be done to repair.
   / Freeing a seized engine with compressed air #4
only way I have ever heard to break a seized engine is filling the cylinders with atf + acteone or pb blaster or a light oil. Let it set, and try to roll it over with a socket on the crank.
   / Freeing a seized engine with compressed air #5
There are some engines designed to start with or compressed air. Tying an air hose to a spark plug access only allows one stroke and that only if the cylinder with closed valves has been chosen.
   / Freeing a seized engine with compressed air #6
My father in law is big into auctions and buys "junk" often. Using the method above, he almost always gets a frozen/old engine to turn over and get running. That is old school, but still works today as always.
   / Freeing a seized engine with compressed air #7
I have 2-3 of the fittings that are home made that I used to replace valve seals without removing the cylinder head.
You just knock the guts out of a spark plug then weld/braze an air fitting to it.
With the fitting on a cylinder and air on it you CAREFULLY remove valve keeper, spring and replace the bad seals. The air will hold the valve closed.
That is old school and I haven't done it in years!
The stuck engines I have seen were too far gone for air to do anything.
   / Freeing a seized engine with compressed air #8
If a shop air supply frees a stuck engine, it wasn't badly stuck to begin with.
   / Freeing a seized engine with compressed air #9
I've seen stuck engines moved with hydraulic pressure applied to the spark plug hole, but air pressure is probably too low if the engine is stuck very badly.
   / Freeing a seized engine with compressed air #10
While I don't believe air would free a stuck engine I do know that air will pop a cylinder head once the bolts are removed.
Even well seated gaskets don't resist and I prefer air to using a pry bar.
2018 CATERPILLAR 242D SKID STEER (A60429)
2018 CATERPILLAR...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
UNUSED FUTURE...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
YanMar SV40 Mini Excavator
YanMar SV40 Mini...
1996 FORD F SERIES DUMP TRUCK (A60430)
1996 FORD F SERIES...
